Dzisiaj jest pt lis 21, 2025 8:07 am
Post: pt maja 05, 2006 9:44 pm
Niebawem zamierzam wymienić płyn w chłodnicy jednak nie wiem ile go tam wchodzi będę wdzięczny za podpowiedz.
Jeszcze jedna sprawa chce kupic płyn mobil 911 plus jakoś w necie nigdzie go nie widze a po sklepach jeszcze nie chodziłem ciężko jest go znaleść (Poznań, Konin)? Jeśli tak to czy wiecie gdzie można w necie go zamówic ?
Post: sob maja 06, 2006 8:14 am
Type 200 CE
Name 200 CE
Name Mercedes-Benz type 200 CE
Short name 200 CE
Model C 124 E 20
Production 03.90/06.90 - 12.92
Number produced 5.921
Comments concerning the production period begin of production - pre-production batch / main production - end of production
Prices not available in Germany
Wheelbase 2715 mm
Track rear/front 1501/1491 mm ("Sportline": 1518/1509 mm)
Length 4655 mm
Width 1740 mm
Height 1394 mm ("Sportline": 1375 mm)
Smallest turning circle 10,99 m
Chassis weight ==========
Max. total weight 1850 kg
Max. front axle weight 910 kg
Max. rear axle weight 940 kg
Max. load 530 kg
Max. trailer weight braked 1500 kg
Max. trailer weight unbraked 715 kg
Weight empty 1360 kg
According to guideline DIN 70020 (with fuel, spare wheel and tool equipment)
Operating method four-stroke Otto (w/ manifold-injection; emission control device w/ three-way catalyst on demand)
Configuration front, parallel; upright
Type M 102 E 20 / 102.963
No. of cylinder/configuration 4 / in line; 15ř inclination to the right
Bore x stroke 89,0 x 80,2 mm
Total displacement 1996 ccm
Compression ratio 9,1
Crankshaft bearing 5
Output 122 hp / 90 kW at 5100 /min (with catalyst 118 hp / 87 kW at 5200 /min)
Maximum torque 178 Nm (with catalyst 172 Nm) at 3500 /min
No. of valves/configuration 1 intake, 1 exhaust / V-shaped overhead
Valve operation top camshaft
Camshaft drive simple roller-type chain
Mixture formation manifold-injection, mechano-electronically controlled (Bosch KE-Jetronic)
Cooling water cooling / pump; 8,5 l water
Lubrication pressure circulation lubrication / 5 l oil
Electric system 12 V
Battery 62 Ah / in the engine compartment
Dynamo three-phase AC / 980 W
Starter motor electrical / 1,4 kW
Ignition electronic ignition system
Fuel tank above the rear axle / 70 l
Fuel supply electric supply pump
Driven whells rear wheels
Power transmission divided cardan shaft
Frame desing self-supporting all-steel body
Wheel suspension front triangle-wishbone / shock-absorber strut
Wheel suspension rear multilink suspension, on demand with hydropneumatic level control
Suspension front coil springs, torsion bar stabilizer
Suspension rear coil springs, torsion bar type stabilizer
Damper gas-pressure shock absorber struts / gas-pressure damper
Steering ball-and-nut power steering
Steering transm ratio 16,21:1 / 3,3 steering wheel turns
Breaking system braking system
Breaking system hydraulic dual-circuit braking system with vacuum-operated brake servo unit and antilock device; disc brakes front and rear
Parking breake parking brake
Parking breake mechanical (foot-operated), effective on rear wheels
Diamatre brake discs front / rear: 284 / 258 mm
Wheels sheet steel-disc wheels, on demand light-alloy disc wheels
Wheels rims 6 1/2 J x 15 H 2; for sports suspension: 7 J x 15 H 2
Tyres 195/65 R 15 91 H; for sports suspension: 205/60 R 15 91 H
Nerwowa Niemra
