Dzisiaj jest wt gru 02, 2025 10:17 am
Post: pt sty 18, 2008 12:00 pm
WDB 1260361A413454, na co zwracać uwagę przy zakupie, ile one palą??bardzo awaryjne??z góry dzięki!
w115 200D 75r.
Post: pt sty 18, 2008 2:44 pm
peterchen pisze:
WDB 1260361A413454
VIN WDB1260361A413454
Model 500 SE
Chassis 1260361A413454
Engine 117965 12 020326
Transmission 722311 03 092080
Order 0 8 204 00738
Approx. year 1988
Lights BOSCH
Cab 00586
Dealer Bielefeld branch (204)
Interior velours anthracite grey (971)
Paint
147 arctic white (T) (с 01.01.1985 по 31.12.1993)
Options
221 left front seat, electrically adjustable (с 01.11.1978)
222 right front seat, electrically adjustable (с 01.11.1978)
240 outside temperature indicator (с 01.03.1982)
245 on-board computer (с 01.09.1983)
280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984)
430 headrests in the rear (с 01.01.1977)
440 tempomat (cruise control) (с 01.09.1975)
471 acceleration skid control (ASR) (с 01.07.1984)
506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989)
outside rear view mirror, right, convex, taxi export version
511 Becker radio Grand Prix cassette electronic stereo, Kurier, LW/MW/USW (с 01.11.1982 по 30.11.1990)
Becker radio Mexico cassette full stereo
Becker radio Monza cassette stereo LW/MW/SW/USW
531 automatic antenna (с 01.01.1963)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
586 Behr air conditioner, and electric window lifters (front and rear doors) (с 01.04.1970)
590 heat-insulating glass, all-around, heated rear window pane (laminated glass), Germany
green heat-insulating glass all round, heated rear window, laminated safety glass - Germany (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
640 aluminium disc wheels with radial-ply tires (с 01.10.1969 по 31.12.1989)
682 fire extinguisher (с 01.04.1970)
731 wood trim, burred walnut root (с 01.08.1980)
S123 300TD
Post: pt sty 18, 2008 3:45 pm
peterchen pisze:
1. Zgodnść z VINem
2. Sprawdzenie (najlepiej z jakimś znajomym mechanikiem) śladów po ew dzwonie, spawanych podłużnicach itp
3. Sprawdź ogólny stan zawieszenia (amortyzatory, gumki itp), oraz geometrię pojazdu, przydałoby się sprawdzenie grubości powłoki lakierniczej, ew śladów rdzy
4. Wycieki z silnika, skrzyni, tylnego wału
5. Układ hamulcowy
6. Kompresja silnika (najlepiej wcześniej wymienić olej - wtedy masz pewność że nie było motodoktorka).
7. Sprawność układu klimatyzacji (naprawy kosztują od 800 do pewnie 2000 zł - zależy czy i co jest ew. uszkodzone)
8. Skrzynia Automat ? nie doczytałem - jeśli tak to sprawdź czy sprawnie i bez szarpania przerzuca biegi (naprawa skrzyni to koszt od 1000 do kilku tysięcy), czy się nie ślizga
9. czy aby przypadkiem numery auta nie były przebijane/przespawywane z innego
10. Czy nie kopci, czy silnik się nie krztusi, czy w zbiorniku wyrównawczym nie ma śladów oleju (albo w oleju śladów płynu)
11. Sprawdź stan wału - a w szczególności stan elementów metalowo gumowych wału
12. Przydałoby się sprawdzić pompę wody, visco, alternator - sprawność, czy nie piszczy
13. Sprawdź tempomat i wszystkie układy pojazdu (ogrzewanie, wentylację, ogrzewanie tylnej szyby, wspomaganie - oraz to wszystko co auto ma w wyposażeniu - powinno być sprawne, sprawdź czy lampki przy liczniku się nie palą - oraz czy są sprawne, czy np wskaźnik ciśnienia oleju po włożeniu kluczyka nie idzie od razu na 3 - powinien dopiero po odpaleniu auta)
14. Sprawdź też oczywiście bezpieczniki - czy nie były watowane, czy któryś się nie przepala, nie stopił/wtopił
15 Na oględziny weź najlepiej jakiegoś mechanika od MB - niech się przejedzie autem i się wypowie
A na koniec: nie ufaj sprzedawcy - jak coś kręci, to daj sobie spokój
peterchen pisze:
ile one palą??
od 12 do ponad 30 - zależy gdzie i w jakich warunkach eksploatowane (miałem kiedyś Toledo, które przy pojemności 1.8 spaliło 10 litrów w ciągu 50 km - czyli 20/100, taki 5 litrowiec przy bardzo mocnym wciskaniu może spokojnie grubo ponad 30 zeżreć).
Spalanie w takim aucie to naprawde tylko część wydatków.
peterchen pisze:
bardzo awaryjne??
I tak i nie. Jeśli poprzedni właściciel o niego dbał i wszystko robił na czas, to auto jeszcze trochę pojeździ. Jeśli auto było zaniedbane, to będzie się mściło. Weź pod uwagę, że to auto ma już swoje lata (w tym roku stuknie mu 20) - i nie oczekuj od niego cudów. Co prawda jest to Mercedes, ale już w kwiecie wieku. O sprawności na poziomie nowej mazdy możesz spokojnie zapomnieć. Choć będzie pewnie ona sporo wyższa (jeśli auto jest zadbane) niz u konkurentów o 10 lat młodszych.
Od czasu do czasu coś w to autko trzeba będzie włożyć, a na początek:
- nowe świece
- przydałaby się nowa wiązka el.
- nowe płyny (w chłodnicy, układzie wspomagania, ukl. hamulcowym, w tylnym moście, w skrzyni i silniku) + oczywiście filtry (silnik, paliwo, skrzynia, kabinowy - o ile jest).
+ pewnie kilka innych dupereli - po kupnie może się tego nazbierać za 1000-2000 zł
Wszystko zależy od tego czy chcesz tym autem długo jeździć (wtedy zainwestujesz więcej), czy kupić - pochwalić się i sprzedać (wtedy możesz przez krótki okres nic nie wkładać w auto). Czego oczekujesz od tego samochodu ?
- Że będzie tani w eksploatacji? Rozczarujesz się - tania w eksploatacji będzie Panda 1,3 JTD lub IBIZa 1,4 TDI
- Że będzie duże i wygodne bez względu na podwyższone koszty użytkowania ? To auto jest dla ciebie
weź pod uwagę, że to auto nie było projektowane dla klasy średniej czy niższej średniej - ono było projektowane dla ludzi, którzy raczej nie liczyli ilości paliwa na 100km czy ceny części przy przeglądach (na przeglądy zabierał takie auto zapewne lokaj).
weź też pod uwagę, że jeśli coś się jednak stanie (a ma prawo - auto ma 20 lat), to naprawy będą dużo wyższe niż naprawa MB W123 czy W124.
Pamiętaj też, że pomimo wieku - są to auta nadal chodliwe wśród złodziei (koledze z naszego forum ukradli 2 lata temu podobne auto). A wiec zainwestuj w jakieś zabezpieczenia i kup sobie AC kradzieżowe (będziesz spał spokojnie). Przy wartości auta 15 000 zł składka za AC kradzieżowe to jakieś 200 zł/rok.
ex. W124 E220 ASB, BRC Seq 24
ex. Corolla E11 1.4
ex. Toledo I 1.8, BRC II Gen
Ostatnio zmieniony pt sty 18, 2008 4:38 pm przez WojtekW, łącznie zmieniany 2 razy.
Post: pt sty 18, 2008 4:04 pm
WojtekW
chciałem tylko napisać ,że jestem pod wrażeniem twojego wywodu :)
Dunkelheit !
Post: pt sty 18, 2008 4:08 pm
Staram się jak mogę :)
ex. Corolla E11 1.4
Post: pt sty 18, 2008 9:39 pm
Wow co za wykład jestem pod WIELKIM wrażeniem!!Gratuluje koledze!!niestety auto nie bardzo (miałem zamienić sie za swego w124), brak zgodności z VIN (możliwe ze przebijane numery), bardzo zniszczony i na pewno po wypadku. Na razie chyba zostanę przy swoje starej eSce i w124!!dzięki wielki pozdr
P.S. dale link do ogłoszenia moze ktos z kolegów bedzie reflektował :roll: :roll: http://www.otomoto.pl/index.php?sect=show&id=C3433611
w115 200D 75r.
Post: pn sty 21, 2008 3:19 pm
WojtekW jestem pod wrażeniem, przeczytałem i praktycznie nic nie można już dodać. Do Moderatorów:
proponuję założyć stały dział lub ogłoszenie w stylu: poradnik zakupowicza, co trzeba wiedziec przy zakupie, itp dla poszczególnych modeli a powyższy post WojtkaW jako pierwszy tam wkleić.
Pozdro.
